Home > Maintenance & Mods (L322) > Need Help fixing rear center armrest handle
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Hi Folks
I was cleaning the car today and noticed that the release handle for the rear centre armrest in my car has come loose. No amount of fidling is making it go back in.
Is there a way to take this apart and fix this? Since I cannot see inside Im not sure how to get it to seat correctly.
Picture attached for clarity
thanks for any help - Im not sure how to fix this
2008 Range Rover
Alex 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #439623 25th May 2017 9:28pm
muddycharles
Bump - anyone have any ideas? 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #454295 17th Oct 2017 5:36pm
Clivefog
I would be interested also.
My handle just flaps, the armrest is stuck in the upright position.
Post #454423 18th Oct 2017 3:31pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Is this the middle seat release handle?
Post #454494 19th Oct 2017 1:51am
doclees
I'm guessing here but I'd assume the surround to the handle from the front has plastic tabs on the sides and even the top. You will need to get a thin trim tool along the sides of it and push inward. Here is the best picture of the cup holder assembly and it is very generic. It looks like two side tabs and a center tab. If you have an inspection camera small enough to get between the plastic and the cushion that might be helpful. Expect to break a tab or two but being ABS plastic you can fix it enough to function.
Post #454497 19th Oct 2017 4:24am
muddycharles
Thanks for your reply
Ill study this to see what I can do.I was afraid it would involve surgery! 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #454612 19th Oct 2017 8:11pm
Clivefog
Thanks for the diagram, don't help me but the mention of endoscope certainly has.
Post #454692 20th Oct 2017 7:51pm
doclees
I'm away until Sunday but duh I have a scope but not the real small one. I'll see if I can see anything with it. Probably somewhat different being a 2004 but maybe give some clues.
Post #454735 21st Oct 2017 2:45am
muddycharles
More Pics
So the cupholder is fastened with clips and I broke some but was able to fix the problem (JB Weld as the handle had broken)
Some pictures so other people can see what this is all about
 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #454988 22nd Oct 2017 11:20pm
doclees
I'm not clear what you did to fix the release handle. I understand fixing the sacrificial tabs on the cup holder that broke with removal. A little photo editing with arrows and or comments would be great.
Post #454997 23rd Oct 2017 12:55am
muddycharles
Tips
So the handle is made of three pieces
One is decorative and slides out
The other two are the mechanism
There is a handle that broke for me. The handle has a knob per side and a handle or hook per side. In my case both one knob and one hook broke off (kids?)
I used crazy glue and JBweld. To glue them back on. (Crazy glue Alone was not strong enough )
There if you look where the handle goes you will see two slots in the bottom the knobs slide into the slots in the hooks face rearward and get hooked into the thin strip that has the two places with the hooks center into if you open your seat up you will know what I mean
I do have to caution you that I broke quite a few of the retaining clips trying to get the cubbyhole out I did not have any of the Plas ic tools that radio installers use 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #455002 23rd Oct 2017 1:35am
doclees
Thanks. FYI it's all ABS plastic. I use a soldering iron with a blade attachment and some scrap ABS plastic or ABS rods. Only thing I've found that bonds ABS for long is to melt it and melt plastic in and around the break. Crazy glue is good to hold in place while you remelt.
Post #455004 23rd Oct 2017 5:37am
