Home > Technical (L322) > Black smoke from L322 TDV8 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7747 |
Most likely a split turbo hose
26th May 2017 5:31pm |
mcj0rdan Member Since: 27 Aug 2016 Location: Crediton Posts: 18 |
Thank you for your quick reply Alistair. I have already had a quick look at the Turbo hoses, I guess I may have to remove them to check properly. Thanks again for your help.
26th May 2017 5:51pm |
Have just removed the right hand turbo hose, and sure enough 3" split!! Thank you Alistair for making me check it properly!
26th May 2017 6:42pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
That's a weird split. Was it underneath? ______________________________
26th May 2017 9:05pm |
Is the split at the intercooler or engine end of the hose? Thanks. ______________________________
26th May 2017 9:07pm |
Glad that's all it seems to be |
26th May 2017 9:09pm |
It is at the engine end on the top, (a bit obscured by some other hoses.) Will be interesting to see if replacement of the hose sorts the engine fault code. I'm also surprised such a serious split didn't send it in to limp mode! |
26th May 2017 10:41pm |
Yep, that should fix it.
26th May 2017 11:19pm |
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 245 |
Old thread resurrection ......
19th Apr 2018 2:22pm |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 508 |
Diagram here: https://www.advancedfactors.co.uk/intercooler--hoses-1949-c.asp
19th Apr 2018 3:40pm |
MikeO
19th Apr 2018 3:49pm |
