Home > Technical (L322) > 2006 Supercharged front differential
Gjlatz
Your thoughts please. When changing the front diff fluid I noticed a couple of drips on the bottom of the diff. When I went to remove the fill plug it was loose I could turn it with my fingers. Fluid changed, drain and fill plugs properly tightened. Checked the diff again a small drip plus the diff case was quick warm plus I could see the threads on the plugs were wet. My question is would a blocked breather cause my symptoms?
Post #440584 4th Jun 2017 9:44am
Big Boy R44ROV
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Fuji White
Possibly, as it would pressurise. Also may be that it has been over tightened or cross threaded in the past and has damaged the threads. Tony
You're always in the Censored ........it's just the depth that varies
2011 5.0 Autobiography Fuji White
2019 Audi Q2 in White
04 SL55AMG
Gone:
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
V8 Lightweight
Too many series to mention !
IID for L322
Post #440589 4th Jun 2017 10:42am
How much oil did you put in? 2008 MY Supercharged
Post #440611 4th Jun 2017 12:49pm
Gjlatz
I put in 0.75Ltr. I was going to put some Teflon tape on the threads but didn't bother??
Post #440626 4th Jun 2017 3:11pm
Gjlatz
Sorted
Hello all, a couple of turns of PTF/Teflon tape around the threads of the fill plug.
Post #440642 4th Jun 2017 6:49pm
