Home > Maintenance & Mods (L322) > Differential and transfer case oils
Les_Paul
United States 2012 Range Rover HSE 5.0 V8 Santorini Black
I am about to replace the fluids in the differentials and transfer case myself.
Front differential needs synthetic 75w90. I can purchase at any auto store in my area for about $15/quart.
Transfer case needs Shell tf 0753. Can't find this anywhere other than the dealership. They quoted $48/quart. Is this reasonable? And is there another place I can purchase it?
Rear differential is electronic LSD. Do I just use the same oil as in the front?
I'm a noob with Range Rovers. Been a Toyota guy my whole life until now...these things are different beasts!
Thanks much!
Post #442256 22nd Jun 2017 3:51am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
The rear electronic diff requires this
Castrol SAF Carbon Mod Plus
Post #442276 22nd Jun 2017 9:56am
Les_Paul
Just wanted to give anyone else who decides to do this some photos of the products I purchased. Again, I drive a 2012 RR HSE Lux 5.0L V8
I spent the extra money and bought the oil from a Land Rover dealer in Houston. The prices are absurd, but I'll sleep better knowing I'm using the correct products. The front differential takes regular ole synthetic 75w-90 gear oil, so I saved some money by purchasing that from Advanced Auto for $11 for a quart.
I included front and back photos of the bottles so you can see exactly what you need.
Front differential - synthetic 75w90 gear oil
Transfer case - LR Transfer Box Oil IYK500010 (supersedes Shell TF 0753)
Rear differential - LR Electronic Differential Fluid LR019727 (part sheet had it listed as Castrol Bot 720)
Also, I showed the invoice so everyone can see the prices.
Hope this helps.
Post #442620 25th Jun 2017 12:29am
