Home > In Car Electronics (L322) > How hard is running a cable into the upper tailgate? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34906 |
stick the dashcam on the tailgate glass and then tuck the cable into the tailgate trim...leave a bit extra loose so when you open the tailgate it wont stretch... ... - .- -.
24th Jun 2017 11:23am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Thanks Stan! I want to get it through the gaitor. Just unsure how to get into that... Cheers, Greg
24th Jun 2017 11:37am |
the rubber gaiter?...you dont....
24th Jun 2017 12:00pm |
The easiest way would be to pull out the upper end of the gaiter from the body , feed the cable through from the open end down into the tailgate, poke a length of cable into the space above the roof headlining and the refit the gaiter. The gaiter fits just like a grommet. You can then fish for the length of cable you poked into the headlining with a length of wire or similar with with the end formed into a hook. Simples |
24th Jun 2017 12:01pm |
stan: yes your technique is good to tuck it in. But I need to get it from the hinged door, through the gaiter (like the other cables) and into the main car body. Do you have a rear cam? If so how do you get your cable to cross the hinged door to the fixed main body?
24th Jun 2017 12:09pm |
this my setup, with the cable tucked into the trim,
24th Jun 2017 3:12pm |
