Home > Technical (L322) > Lack of power - S/C |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
My gearbox is not great and bangs into gear when stationary etc...
17th Jul 2017 9:30am |
Only other thing that has happened recently is running out of petrol and reduced engine performance on the dash because of no petrol before it cut out. However, LR have said no faults or unable to find anything wrong with the car. However, they can hear the noise and have heard it on the video I have sent to them.
17th Jul 2017 10:33am |
It is certainly worth asking the question.
17th Jul 2017 12:13pm |
Crispian22 Member Since: 25 May 2017 Location: Midlands Posts: 133 |
Having a quick look on the internet,there have been a few reports of front diffs making the noise you describe.Diagnosis seems to be to drop the car into neutral at speed when it makes the noise,Not something I'd do personally,but if the noise persists then you know it's not engine related.
17th Jul 2017 12:17pm |
I can't think of a mechanism that would cause it but that doesn't mean it can't have happened.......
Also reports of alternator bearings and water pumps on the way out.
17th Jul 2017 12:22pm |
Ok, will suggest it to LR to have a look at.
17th Jul 2017 1:27pm |
Have also had a new alternator as it failed completely after whining away for a few months and not the same noise as before. Alex
17th Jul 2017 1:29pm |
xjsracer44 Member Since: 30 Nov 2010 Location: Hertfordshire Posts: 274 |
Could it be that the backfire damaged the catalytic converter on the passenger side when you ran out of fuel and that's causing the restricted performance and the noise?
17th Jul 2017 1:33pm |
Possibly yes. I had a thought that the nearside cat had broken up and was partially blocked and air noise was exhaust gas coming back up the pipe again.
17th Jul 2017 1:59pm |
Be carefull taking the sensors out, the threads are easily damaged. Use plenty of lubrication or the stainless steel will "bite" badly !!! I had to rethread the exhaust hole on my SC 4.2. MY 2010 5.0 SC Galway green and sand interior!!
18th Jul 2017 10:43am |
So LR still cannot get to the bottom of this presently. They have sent a technical case to Land Rover who have not come back with anything useful.
19th Jul 2017 1:57pm |
How did you get on with your inspection of the cats?
19th Jul 2017 5:07pm |
I haven't checked them, yet.
20th Jul 2017 11:11am |
