Home > Maintenance & Mods (L322) > For You IID Tool Gurus
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
Well now that the old girl is serviced, just been playing with the IID this morning to try and get more competent with it.
I know I have to regenerate the DPF to clear the fault and sure enough it's the only thing coming up
I was looking at live values and specifically the EGR readings, when does the second valve actuate? I gave the throttle some beans and only the first figure altered, when you change to the graph view first wavey line second flat.
Also in the section for updates on ECU's, where it says update available, where to you get this? Stealer I presume!
Could someone in the know maybe explain some of this to me please?
Thanks as always.. Thumbs Up
 Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443286 2nd Jul 2017 1:06pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
I've no idea about the 4.4 v8, but csn only assume that the 2nd egr and turbo will not come in until the engine is under load.eg.driving it.
just a stab in the dark.
Post #443335 2nd Jul 2017 8:24pm
stu
Sounds plausible, I just thought blipping the throttle might activate it Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443341 2nd Jul 2017 9:15pm
mpirie
I believe the second turbo on the 4.4 TDV8 doesn't start to boost until 2500rpm, so blipping the throttle would not be enough to generate a reading.
Post #443363 3rd Jul 2017 9:50am
