Home > General > 2004 TD6? |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3057 |
Gearbox
8th Jul 2017 9:09am |
Water ingress in the rear left side compartment.
8th Jul 2017 9:30am |
There will be rusty brake pipes - front, rear and connecting (all hidden away under plastic covers) unless your friend has had them replaced .
8th Jul 2017 12:17pm |
sheep911uk Member Since: 09 May 2017 Location: Northampton Posts: 30 |
Will that have been picked up on previous Mot? |
8th Jul 2017 12:41pm |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
No. MOT testers only report on what they can see, they do not remove parts at all.
8th Jul 2017 11:37pm |
But if the rest of the car looks sound, don't neccesarily let that put you off. The aren't a fortune to replace. There is nothing that can't be fixed with a hammer😜😜
9th Jul 2017 9:02am |
Thanks all, I also need to weigh up the options between buying this with 77k and no gearbox work having been done or buying a higher mileage one which has had the gearbox replaced.
9th Jul 2017 11:22am |
Diesels hate short trips, they are designed to be running all day long (hot) e.g. fairground generators.
9th Jul 2017 11:24am |
Cheers not keen on petrol option. |
9th Jul 2017 11:58am |
