Home > Maintenance & Mods (L322) > Oil Leak of some sort |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1340 |
I don't know the source of your leak, but mine leaked gear box oil from the join between engine and gearbox, needed a new gearbox as 2 litres had been lost, so worth checking if it is that. Only Range Rovers since 1988 |
8th Jul 2017 2:41pm |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
oh dear..
8th Jul 2017 3:20pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
scotcruz if you have 4.4TDV8 than the oil leak is most probably from leaking O ring in the back of the engine. excellent tread how to fix it started by Cam-Tech-Craig.
8th Jul 2017 4:30pm |
cheers mate.. mines a 3.6 TDV8 but will have a read and hope it is that and not the gearbox seal.
8th Jul 2017 4:42pm |
