Home > Technical (L322) > In tank fuel pump |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
17th Jul 2017 7:18pm |
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 297 |
Thanks Stan
17th Jul 2017 7:33pm |
download the WM , its all in there...
17th Jul 2017 9:11pm |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
I've been doing some research for you, I believe that the low pressure sensor is part WKW000060, located on top of the fuel filter housing as shown in the picture below:
17th Jul 2017 9:58pm |
Thankyou all for your help will keep you advised of the progress 👍 |
18th Jul 2017 9:30am |
Replaced both fuel pumps both the main one and the secondary one main pump was a pig of a job the pipe from the pump it self is plastic and flexible unfortunately you have to cut the black pipe to get the pump off replacing it was a nightmare Carwoods had the pipe but refused to he
25th Jul 2017 9:52am |
