Home > Technical (L322) > 8 speed gearbox oil flush recommendations and advice please |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34871 |
curious to know if it drives any better Stu.. ... - .- -.
30th Jul 2017 8:51pm |
that's good to hear Stu... ... - .- -.
31st Jul 2017 6:17am |
sparkyxm Member Since: 14 Jan 2018 Location: Warwickshire Posts: 2 |
Hi all,
18th Jun 2018 2:47pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2278 |
For your possible wheel bearing noise, check that the pipes from the ABS modulator are all properly spaced apart by the spacers. I had a right front wheel bearing replaced to no avail trying to fix this noise only to discover an unattached pipe was vibrating on an adjacent pipe well down the void. |
18th Jun 2018 8:53pm |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 |
Whats the name of the place in Selby. I need to replace a sensor too which is housed in the sump 2011 RR Autobiography 4.4 TDV8 |
21st Jul 2018 7:34pm |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
This is interesting - my 2011 was in for a megaflush and service but my indie (used for 20 years and totally trustworthy) called me up to ay you can't do a megaflush on the 8 speed box as there is a thermostat in the system that closes when the cold flush fluid hits it preventing the flush...?
21st Jul 2018 8:11pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16146 |
That seams far too cheap sir... The oil is £48 per litre from JLR let alone the cost of the filter! |
21st Jul 2018 10:52pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1684 |
The 8 speed CAN be flushed without issue |
22nd Jul 2018 5:56am |
the place in Selby? Whats it called? 2011 RR Autobiography 4.4 TDV8 |
24th Jul 2018 4:16pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3660 |
24th Jul 2018 4:39pm |
As always, thanks Mike 2011 RR Autobiography 4.4 TDV8 |
24th Jul 2018 4:40pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3517 |
saw this posted by Grofus:
Wondering if this technique is possible on the 8-speed ? Planning to change the fluid but I want to change more than the 4 that'll come out by gravity. Total capacity is 8.5litres. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
9th Oct 2018 7:30pm |
No
10th Oct 2018 7:02am |
Ok thanks a lot Mikey
10th Oct 2018 7:39am |
