Home > Technical (L322) > Eaton M112....The old & the new!??!
Dreckly
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Hi All,
This afternoon I removed my old Supercharger ready to fit the new one with the 10% pulley, so for those who might still have an interest in changing their pulley on their 4.2 S/C, but don't know the difference, here you are:
Cheers,
Ken 55 S/C L322 Zambesi Silver.....GONE!!
56 S/C L322 Java Black......surviving at present...just!
04 N/A 4.2 V8 S Type Jag
1961 reg 3.5 V8 Bowler Tomcat.....Sold
Numerous Classic (rusty!?!) Minis
Post #445531 23rd Jul 2017 9:11pm
rar110
So what happened to the old supercharger? ______________________________
Post #445538 23rd Jul 2017 9:36pm
Dreckly
I have a really harsh bearing noise coming from high up in the area around the rear of the charger. The usual thing....the noise was only under load and roughly between 1800 & 2300 rpm (the rev range where most driving is done), so I am thinking that it is the rear bearings in the charger. My car has done 186K miles so my thinking is that the charger bearings would probably need replacing. I also really fancied a 10% pulley upgrade so when I found a NOS unit with unmarked teflon coated rotors on the bay of thieves for silly money, it was a no brain decision. I had the new charger sent to Powerhouse who checked it over (yes definitely new), re-greased the bearings (as a sensible precaution) & installed the new pulley. Very Happy
When the new "metal throttle body to elbow gasket" (9E931 £0.80+ VAT) and rubber "elbow to charger gasket" (9M436 £3.65+ VAT) arrive from Land Rover tomorrow I'll throw it all back together..... Rolling with laughter
Cheers,
Post #445561 24th Jul 2017 10:57am
verydisco
sweet thanks for sharing this indeed. Looking forward to the install pics too if you don't mind, then video with sound!!! Wink l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #445563 24th Jul 2017 11:38am
Dreckly
I took pictures all the way through the strip down so can do a blow by blow pictorial account of removal then rebuild if people want!??! 55 S/C L322 Zambesi Silver.....GONE!!
Post #445566 24th Jul 2017 12:31pm
verydisco
thanks, that would be very useful for the wiki here. Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #445595 24th Jul 2017 6:21pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
we want Thumbs Up Thumbs Up
Post #445597 24th Jul 2017 7:50pm
Strider
Want one, want one, as you have a stopwatch in the screen menu 0-60mph might be interesting.
Good Luck Thumbs Up
Post #445603 24th Jul 2017 8:22pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Yes that would be good to see thanks.
This is something I will consider now mine seems to be fixed.
Interesting to see what long term effects it has on fuel consimptsnd performance alike
Cheers and good luck! Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #445742 25th Jul 2017 6:24pm
dan_uk_1984
Did it cure the noise is the main question Smile
I cut the belt on mine to stop it being driven, but the noise persisted so was confident it wasn't SC... I have a long list of what it isn't lol.
Post #445760 25th Jul 2017 8:32pm
Dreckly
Hi All,
Well it's 9.25pm and I've just finished throwing it back together.....yes I know "what took so long?" but it's not the easiest of jobs.....the parts didn't arrive until gone 4pm.....I've been to a planning meeting this evening.....it's dark and raining and I've been working outside...... and, and.....Whistle Very Happy
Everything's all properly cleaned up and looking good but I've had to re-use the old "throttle body elbow to charger" gasket because "Land Rover couldn't find one at the factory"....???? It seems OK, isn't leaking and looks to be designed to be re-used anyway.
I probably made life more awkward for myself because I've done the job without disconnecting any of the cooling system, electrical connections and I am currently still running the old belt, but I've now got to strip the front down to change the air con condenser, so I'll probably fit the new belt then.
Right then, a word to the wise!!
"If you are going to attempt to change your charger yourself at home unless you are about ten feet tall with elastic arms and surgeon's fingers use your IID tool to drop the suspension down to "transportation!??!" height"!!
You know.....the setting lower than "access height". I made the mistake of only going to access height and I'm on 255/55R20 tyres, so I've been climbing up & down a lot or lying full stretch on top the engine which ain't comfy!!
OK so the important bit:
Yes, she spools up very,very quickly on no load, and yes she whines nicely (but that might just be the old belt) however I've not driven her yet because I've already started stripping out the slam panel so the headlights are loose. If we don't get the liquid sunshine we are promised for tomorrow then I'll attack the condenser but this also not that easy because it is sandwiched the S/C and water rads......the joys of owning a S/C Fatty......!??! Confused
Now off to find some food!
Cheers,
Post #445769 25th Jul 2017 10:27pm
Dreckly
Very Disco..... I'll write a "How to" when I've finished it all, and managed to compress the pictures etc. Rolling Eyes
Dan...... I'll let you know when I've driven her, but knowing my luck......!??!
The new charger is much smoother and, if you ignore the whine, it seems much quieter. The downside is that it has emphasised other noises from the front of the engine, but I'm hoping that this will improve again when I change the belt for the new one.
I'll keep you posted,
Cheers,
Post #445775 25th Jul 2017 11:33pm
zarnd
Sounds good and looking forward to the pictures
How do you go lower than access height?
Cheers Alex
2007 M5 Touring
2004 SL55 AMG
Post #445777 26th Jul 2017 5:31am
Dreckly
I've got the IID BT version and it gives me the option of lower again than access height, which from memory is the transportation setting & probably used for going on and off car transporters.
You couldn't drive anywhere like it because the wheels are pretty much right up in the arches and she'll probably also be on the bump stops. 55 S/C L322 Zambesi Silver.....GONE!!
Post #445848 26th Jul 2017 4:29pm
Dreckly
Well I drove her yesterday for a 40 odd mile round trip. All "A" roads (there are no motorways in Cornwall) and a what a pleasing difference. Thumbs Up
Previously when you pressed the throttle gently for sensible "in traffic" driving there was what seemed like a delay and it required more pedal movement than you would expect. Not any more.....very gentle pedal movements = gentle increases speed and big pedal movements = huge increases in speed !! Very Happy
When you bury your throttle pedal in the carpet the car takes off with a vengeance, but it does not seem as dramatic as before, probably because the charger was already spinning faster!? Confused
In general the whole driving experience is much smoother and feels even more refined than before. My feeling is that consumption should improve slightly because less throttle opening is required for given speeds because of the smaller pulley.
Now everything is assembled there is slightly more supercharger whine on hard acceleration, but for normal gentle and "in traffic" driving there isn't an appreciable difference.
The overhaul of the charger (or in this case replacement) was definitely worth the expense and in my opinion so was the 10% pulley upgrade. I now have one less bearing noise to worry about, which is great, but am probably now in the same position as Dan_uk_1984, with other noises to eliminate.
Cheers,
Post #446238 31st Jul 2017 12:21pm
