Home > Technical (L322) > AGM battery in an L322? |
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 |
Been having the flat or very nearly flat battery problem again and it has been suggested to me that I could fit an AGM battery.
24th Jul 2017 9:03pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7629 |
What's the advantage? I think I have one in my 2011. Sorry, I know it's not answered your question.... 2011 Range Rover Vogue SE 4.4 TDV8
24th Jul 2017 10:06pm |
It was suggested by an AA mech after I called them out for the fifth time to a flat battery. He said that there is something causing a drain while the car is parked over night which doesn't allow the battery to cycle properly and is causing damage to it. Apparently AGM batteries are designed to handle this and are better able to cope with the demands of a td6. Has anybody had similar problems and tried this? QUID FACIUM TIBI
24th Jul 2017 10:16pm |
Well, I do like AGM batteries but only for their ability to cycle a lot more than lead-acid. They don't have any more capacity although they will give a high enough output to start from a much deeper level of discharge. But the bottom line is simple, if you have a drain it needs fixing or you will get more flat batteries, it just takes longer with AGM. |
25th Jul 2017 8:29am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2213 |
I put one in a few years ago as mine has a heater in it although it is petrol more as a safeguard and it has been great but as has been said its not the battery at fault it is the drain you need to sort that first |
25th Jul 2017 12:16pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
A 2003 ffrr wont provide the correct charging voltage for an AGM battery, so you wont get the best out of it..... If your battery is going down overnight then it's either a dud battery of you have a drain going on, most likely something in the boot is swimming in water... nav, radio , tv etc
26th Jul 2017 12:12pm |
There is no water ingress and everything turns off. One thing though, after locking the car I sometimes hear a loud fan come on (sounds like the blower) but it doesnt stay on very long.... QUID FACIUM TIBI
26th Jul 2017 9:00pm |
That will be the remote cabin heater... which is under the battery.. they have a mind of their own and just spring into life as they please! If the rest is ok then I'd suspect that your battery is past it's sell by date and it's time for a new one...
27th Jul 2017 11:12am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 701 |
I am no expert but I was wondering about my battery going flat
27th Jul 2017 11:40am |
The battery (Varta) was new last October. Ive been to a specialist today and their machine says the battery is ok, just needs charging. I wasn't totally confident though as they then tried to sell me a mains converter as a booster..... QUID FACIUM TIBI
27th Jul 2017 7:37pm |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 144 |
The computer will attempt to level the car by lowering it.The compressor will not come on.This can not drain the battery flat! 2012 TDV8 Vogue SE 4.4 |
27th Jul 2017 8:24pm |
I would get the output of your alternator checked |
27th Jul 2017 8:58pm |
10th Aug 2017 2:49pm |
That is a P38
11th Aug 2017 12:25am |
