Home > Technical (L322) > Sticky front caliper |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
I'm running a TD6, but has anyone else had this problem?
25th Jul 2017 1:29am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1263 |
it sounds to me its not braking on the passenger side , you should not be able to touch the disc without burning yourself |
25th Jul 2017 4:49am |
Thanks GregDav
25th Jul 2017 5:42am |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 120 |
Could be moisture in your brake fluid. I had this once on a ford van and it totally locked up the wheel. After using the brakes a few times the fluid expanded with the heat and locked up the wheel. I changed the fluid and all was well. 2011 4.4 TDV8 Vogue SE
25th Jul 2017 12:18pm |
Thanks, will have a look.
25th Jul 2017 12:26pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1335 |
I'd replace the caliper(s). The passenger side would tend to seize first as it's nearer to the side of the road and hence picks up more dirt. On my 2004 car the passenger side seized, with the car shuddering as I drove and then clouds of smoke when I stopped. The problem was with corroded pistons. After a roadside repair the permanent solution was a new calliper.
25th Jul 2017 3:01pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3951 |
I had a front caliper stick, the disc got very hot and had vibration whilst driving.
25th Jul 2017 3:12pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3628 |
I agree with the other posters on here that touching the disc is not a good idea - it gets too hot. However when My caliper failed in a similar way the wheel got hot and the fuel consumption increased. I replaced one and then the other followed it so I would say replace in pairs if you can. Geoff |
25th Jul 2017 5:32pm |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 144 |
Has the brakefluid been replaced?Should do it every 2 years!I have also seen that when the rubber brakepipe gets older,that the inside will rot and go soft,resulting in the caliper to stick as the fluid is not flowing freely. 2012 TDV8 Vogue SE 4.4 |
25th Jul 2017 7:19pm |
