Home > Maintenance & Mods (L322) > Cost of new DPF? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
He doesn't post often, but little gems of advice like this, remind me how much I miss your contributions Craig. G reg 2.5VM Vogue Portofino red 1991- 1999
1st Aug 2017 8:12am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
+1 mr blue |
1st Aug 2017 9:40am |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 452 |
Hey everybody Craig's back (well back-ish). Welcome old chap. Don't be a stranger. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
1st Aug 2017 10:02am |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
thanks all for your help/advice.
1st Aug 2017 11:14am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
1st Aug 2017 11:17am |
Many members 4.4 tdv8's have done over 100k miles, but I don't remember anyone saying they have replaced their DPF. G reg 2.5VM Vogue Portofino red 1991- 1999
1st Aug 2017 3:37pm |
After getting the car back from the main dealers who refused to do anything except wanting to fit a brand new DPF, I tried what Craig said when I got home. Sadly hard resetting the battery made no difference. I tried 3 times and each time when reconnected the car went straight back into the RED DPF message and limp home mode so impossible to do a passive regen. Cant find any DPF cleaning specialists near me so I think I'll see how easy it is to take it off myself and courier it to one. If it's not an easy job then I may have to bite the bullet. no - holiday for the kids this year |
2nd Aug 2017 4:45pm |
3rd Aug 2017 11:04am |
I have found an alternative picture for you.
3rd Aug 2017 11:35am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
I'm not able to check this myself at the moment, and don't know if it's possible, but can the IID tool force the car to do a regeneration cycle?
3rd Aug 2017 12:56pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34912 |
mobile cleaning???
3rd Aug 2017 1:51pm |
Having now read that the whole exhaust system including cat, DPF , and rear silencer are made from stainless steel, I can now see where the £2500 replacement price comes from, but surely it also makes more sense to get it cleaned somehow?? G reg 2.5VM Vogue Portofino red 1991- 1999
3rd Aug 2017 2:11pm |
Thanks Stan - as mobile, they can only trigger an active regeneration the same as LR tried but failed. Passive or active regeneration can only clear soot built up. The problem is not soot but soot that has previously failed to burn then becomes ash. The ash then collects in the DPF which can't be burnt off so the DPF has to be removed from the car if cleaning is to be successful and even then apparently there is no guarantee.
3rd Aug 2017 2:16pm |
Well, now I've just uncovered something that may change this. Yes - as I found out this morning, from new manufacture, the DPF is part of an "all in one" exhaust. But having just read the second page of what you attached earlier Blue, it would seem (I'm waiting for duckworth Dan to confirm) , that replacement DPFs may not include a full system. You actually have to CUT out the centre section of the old DPF/system, mount the new DPF and pipe and fasten at each end with Sleeves and clamps. mmmmmmmm |
3rd Aug 2017 2:22pm |
