Home > Maintenance & Mods (L322) > Detailing Polisher - Advice |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
As some of you may be aware, i like to give my car a good clean and then wax so on.
13th Aug 2017 11:01am |
buffalo4 Member Since: 01 May 2016 Location: Doncaster Posts: 143 |
I have been wondering about this one...
13th Aug 2017 11:22am |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
I have this kit and it's been great..also comes with pads
13th Aug 2017 3:35pm |
Consider which of the 2 types of machine you are going to use, I.e. Rotary or dual action. I know little about DA machines but if a rotary is your thing a Makita 9237 is a well made bit of kit. I have 2 of them and they make progress quite rapid. |
13th Aug 2017 3:38pm |
Crispian22 Member Since: 25 May 2017 Location: Midlands Posts: 134 |
If your looking to get into detailing,to start with I'd recommend getting a dual action,less likely to knacker the paint up which can easily be done with a rotary which requires more concentration and technic.
13th Aug 2017 4:55pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
Thanks for the info Crispian Current: TDV8 (3.6) RRS HSE
13th Aug 2017 6:24pm |
stucart Member Since: 03 Jul 2016 Location: Staffordshire Posts: 84 |
I purchased a Dodo Juice DA kit and have had really good results with it, plenty of info on YouTube to steer you in right direction, was a little nervou at first but seems you can't do much wrong with a DA polisher as compared with the old rotary ones, certainly gets rid of swirls on my Black RR paint, used Meguires Ultimate compound and a water spray from a trigger bottle stop it drying out as polishing, do part panel at a time, wiping off with microfibres cloth. 👍 |
13th Aug 2017 7:23pm |
Look at this on eBay http://www.ebay.co.uk/itm/141917382151
So i was looking at wrong type !
13th Aug 2017 7:38pm |
Looks the sort of thing to get you started.
13th Aug 2017 7:57pm |
Billaboard Member Since: 03 Aug 2017 Location: Wirral Posts: 74 |
Errm, what are he polishers they sell in Aldi (and are often remaindered) and why would they be no good? |
14th Aug 2017 12:40am |
Those would be the mini 12 volt things as sold in Halfords, car boot sales etc. Being only 12v and also direct drive from the motor to the head they have very little torque. This is important to maintain a steady head speed with different pressures so as not to bog down and mar the paint.
14th Aug 2017 8:02am |
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 |
I have one of those, they're mains powered and quite powerful for a cheap polisher. However, there's only one mop as such and two slip on covers to fit over it. They're orbital but not got much throw, so the pile on the head seems to take up the orbital throw to a certain extent. For just general polishing they're ok, easier than hand polishing. On flat bits like roof and bonnet I dropped the polisher on a micro fibre cloth, so the polisher does the work. That brings up a real good shine Personally I'm thinking of knocking up some new mop covers oput of micro fibre cloths as I think they'll be better, be a decent tool then |
14th Aug 2017 7:07pm |
IIRC Meguiars do a microfibre kit to go with their DA polisher. |
14th Aug 2017 10:30pm |
