Home > Maintenance & Mods (L322) > Urgent A post photo required 2011 MY |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
Wife is just putting tea on the table Adrian, but will do in half an hour . G reg 2.5VM Vogue Portofino red 1991- 1999
16th Aug 2017 6:08pm |
Crispian22 Member Since: 25 May 2017 Location: Midlands Posts: 133 |
16th Aug 2017 6:33pm |
The flappy bit at the end is attached to the roof finisher trim and literally just sits there.
16th Aug 2017 6:35pm |
16th Aug 2017 6:37pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34907 |
pics sorted mike.. ... - .- -.
16th Aug 2017 8:09pm |
Thanks Stan, you really need to give me lesson in picture posting.
16th Aug 2017 8:51pm |
....or this which is much easier, turn the camera!!! ... - .- -.
16th Aug 2017 9:00pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2213 |
I had a similar problem with auto glass a few years ago and they took it in and replaced the windscreen yours has been fitted wrong when they are fitted correct the trims all fit flush also they should have used new trim not the old one as it gets twisted when they take it off hope that helps |
16th Aug 2017 9:12pm |
Would hazard a guess it's a couple of mm to high. Would take a pic of mine, but I'm away, so can't. In any case never been a really good fit! There is nothing that can't be fixed with a hammer😜😜
16th Aug 2017 9:16pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
Many many thanks folks. This is very much appreciated and reinforces my concerns.
16th Aug 2017 11:20pm |
Make sure your roof trim is pressed down securely,The flappy bits in the corners are fixed to that.
16th Aug 2017 11:29pm |
16th Aug 2017 11:32pm |
Thanks again.
17th Aug 2017 5:20pm |
