Home > Maintenance & Mods (L322) > 4.4tdv8- Anybody heard of leak cylinder head oil press. plug
GGDR
Had mine in at an independent and he's flagged an oil leak saying "oil leak cylinder head oil pressure plug"
Haven't had a chance to speak to him yet as I'm away but wondering if anyone's come across this?
He's saying It needs a gasket and the location is behind the vacuum pump. That's what will take must of the work.
. Cheers, Greg
Post #448113 17th Aug 2017 2:03pm
GGDR
This is exactly what was written:
. Cheers, Greg
Post #448216 18th Aug 2017 5:38am
nino_nino
gonna_go_double_r
I had oil leak from the front of the engine and it was this large inbus bolt located right under thermostat. I was able to unscrew it (you can't take it out because of the thermostat) put some gasket silicon and retighten it. no more leaks Very Happy . it is fiddly job, i used coathanger wire and cotton swab to apply silicon but it is doable. if you take throttle body of it makes job much easier.
white circle indicates where to look:
you may wanna check yours to.
Post #448376 19th Aug 2017 1:25pm
GGDR
ok thanks a lot nino.
My leak is at the rear, he has also identified (separately) the classic 2 o-ring leak from the turbo oil feed pipe. Then said they couldn't see the actual source of the other leak. I said probably the same, no? And he said they would need to do the o-rings, clean it then check again. Which makes sense.
So might not be anything other than the o-ring leak.
. Cheers, Greg
Post #448601 21st Aug 2017 8:18pm
nino_nino
do you get any oil in the antifreeze?
Post #448608 21st Aug 2017 8:45pm
GGDR
err - didn't check... What is that from?
. Cheers, Greg
Post #448610 21st Aug 2017 9:03pm
nino_nino
when i had O rings leak I also had leak from the oil cooler itself which was leaking oil to the outside but also inside into the antifreeze.ended up changing gaskets. check pictures i posted in the "4.4 TDV8 Oil Leak Fix".
Post #448616 21st Aug 2017 9:26pm
GGDR
ok thanks Nino I'll check that out.
. Cheers, Greg
Post #448636 22nd Aug 2017 7:01am
