Home > Maintenance & Mods (L322) > Rear Hub Knuckle Bush Movement |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 498 |
Hi,
22nd Aug 2017 10:57pm |
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 230 |
Strider.
23rd Aug 2017 8:48am |
Hi John,
23rd Aug 2017 11:49am |
Peter. Many thanks for the great information. I will purchase another Bush first to see if that is the problem. Am I correct in thinking that the special washer fits on the outside of the upper arm to mimic the bolt head?
23rd Aug 2017 1:31pm |
Hi John,
23rd Aug 2017 7:48pm |
Peter.
24th Aug 2017 8:34am |
Senior moment |
24th Aug 2017 1:15pm |
Replaced the bush today with a Lemforder one. Now all ok. The bush that I had fitted was faulty, the inner section was moving back and forth within the outer section. Not sure of the make but will return to the supplier for a refund and to find out the make. Have you any experience of replacing a rear diff? Mine appears to have play/noise in/from the driveshaft output bearings. |
26th Aug 2017 1:36pm |
Hi John,
26th Aug 2017 10:13pm |
I am yet to fully investigate the "noise" from the rear, but during the bush replacement I moved the drive shaft - diff end- up and down and there was some movement. However, I need to get it on a four poster ramp and investigate properly, as I have been informed it needs to be done with the shafts in the level position. Fortunately I have access to a fully equipped workshop.
28th Aug 2017 4:58pm |
Regarding welding I know exactly what you mean, I ended up buying a Mig Welder, tried gas bottles but ended up using cored 0.8 wire. When I sold the bus it was on its second set of outer sills. They certainly get in your blood thats for sure. |
28th Aug 2017 7:54pm |
