Home > In Car Electronics (L322) > Date set in Euro format |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 911 |
If your TD6 is a Vogue then I guess you have the sat nav system fitted? If so, just go through ‘SET’ to ‘DATE’ and you can change the format there
5th Sep 2017 5:17pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
Slightly off topic but "How on earth did you get 31.5 degrees in Coventry?"
5th Sep 2017 5:28pm |
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 297 |
I have done that and pressed ok but the display still stays the same 😥
5th Sep 2017 5:50pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Hi, change the clock to 24hr format, that will show correct format of date.
6th Sep 2017 7:37am |
Hi gregdav I have also tried that aswell but to no avail |
6th Sep 2017 3:59pm |
robanzac Member Since: 07 Dec 2017 Location: New Zealand Posts: 15 |
Simran0211
9th May 2018 1:52am |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 559 |
Its possible your instrument cluster may have been changed at some point. Try looking at what option 10 in the hidden instrument pack menu is (check the wiki) to see if its a metric or imperial country setup on the pack Current Fleet:-
9th May 2018 8:22pm |
nicksaab,
31st May 2018 6:36am |
Its possible that the IID tool might reprogramme it, failing that possibly dealer software? Current Fleet:-
31st May 2018 8:36am |
Miserable Old Codger Member Since: 28 May 2018 Location: Cornwall Posts: 11 |
Hi Nicksaab,
31st May 2018 10:03am |
Correction UK Binnacle YAC 501220 and Japanese YAC 501230.. Not just old but obviously now the mind can't get things right first time... Well I suppose there are sometimes advantages having to do things twice to get them right.... |
31st May 2018 10:12am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
The other way around - the Imperial gallon is 20% larger than a US gallon. Ron B. VK2OTC 2004 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
31st May 2018 11:25am |
p38arover,
31st May 2018 11:35am |
See, see, I can't even do that first time, I tried to get a smile in there but only got the link ... |
31st May 2018 11:39am |
