Home > In Car Electronics (L322) > Instrument cluster |
horsedentist Member Since: 23 Jun 2017 Location: london Posts: 158 |
I just had mine done and I watched the guy do it he broke off several clips on the back with pliers in order to get it open. |
9th Sep 2017 9:40am |
Gold Ranger Member Since: 31 Mar 2017 Location: East Midlands Posts: 33 |
try straightening the black lugs straight and then the cluster should pull apart |
9th Sep 2017 11:01am |
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 |
Hello, well i managed to get it apart withut breaking anything off but i now find i have the bonded tape on the ff.i had bought the non bond and so i am not sure if this will work. I cantget thetape to stick and when i try to assemble it the tapejust falls out. Is there a special glue to use or am i up thecreek without a paddle ? |
9th Sep 2017 11:02am |
make sure you get rid of any old glue on the circuit board - i used cotton buds and nail varnish remover on mine - you need the contacts to be nice and shiny
9th Sep 2017 11:08am |
Thanks for that i will give that a try, the videos i watched just stuck it down so i thought there must be some trick i was missing. |
9th Sep 2017 11:16am |
Well its done but not perfect, but better, now this has raised another issue, i have had the suspension inactive issue for a while and have tried a number of remedies, this was partly why i attempted to do the pixels so that i could read what my iid tool was showing. Befor doing the pixel the suspension error used to clear after standing a while, an hour or two, then it would only show after traveling about 5 mins. Now after removing and refitting the instrument cluster the inactive suspension will not clear even using the iid tool, i did the hard reset disconnecting the battery, no change.any ideas? |
10th Sep 2017 12:45pm |
have you done the steering wheel reset?
10th Sep 2017 12:47pm |
Done that i just fail to see what the instument cluster has to do with suspension falults except to report, not cause.the iid tool reports temporary suspension disable and clears the fault but as soon as i switch off bong and inactive suspension. |
10th Sep 2017 1:25pm |
I had that on mine but I drove round my paddock 360 degrees on full lock cleared and has not come back again. When I had my cluster repaired it reset everything on the main computer for some reason. |
10th Sep 2017 1:46pm |
Land Rovers will always amaze you with its capability and its ability to amaze, i will now look for an appropiate runway. Thanks for the tip. |
10th Sep 2017 2:32pm |
Richy Member Since: 12 Sep 2017 Location: Tyne and Wear Posts: 1 |
Just got mine back today after I was too scared to do it myself!
12th Sep 2017 10:40pm |
