Home > Technical (L322) > Buzzy vibration from top of dash
cadoganpier
United Kingdom 2018 Range Rover Autobiography SDV8 Loire Blue
I've got a 2012 TDV8 and there is a really annoying buzz from the top of the dash on the passenger side, it appears to be coming from under the area where I guess the airbag comes out of the top of the dash. I've tried whacking it, pushing on it and generally fiddling but nothing works, now I've noticed it it's driving me potty. Any ideas?
Post #450885 14th Sep 2017 8:55am
CS
I had this. It was caused by some ducting not having been attached properly when the car was built. Having identified the sound by accompanying me on a drive the dealer workshop then took the top off the dash and looked for insecure fittings, apparently the cause was obvious once the area was exposed. After I got the car back there was a clicking from a different area, so it went back again for reassembly and no more noises after that. Only Range Rovers since 1988
Post #450909 14th Sep 2017 12:29pm
cadoganpier
Thanks for the response, do you mind me asking what year yours was?
Post #450911 14th Sep 2017 1:04pm
CS
Sept 2012 WM TDV8; you can see this for all forum members who have a car symbol beside their names by hovering the cursor over the car. Only Range Rovers since 1988
Post #450912 14th Sep 2017 1:59pm
cadoganpier
Ah, thanks for that!.
Post #450913 14th Sep 2017 2:01pm
cadoganpier
Well I bit the bullet and with help from the good people on here took the dash top off to try and sort out my annoying buzz/rattle. The only real problem was the 2 10mm bolts that secure the bottom of the airbag to the cross brace strut thing under the dash, that was a Censored to get at. Anyway I couldn't find anything obvious save for the sound deadening that had come adrift from the dash top. I resecured this with contact adhesive and then bolted it all back together and so far it looks like the rattle has gone, a result and a few hundred pounds saved.
Post #452538 30th Sep 2017 2:45pm
