Home > In Car Electronics (L322) > Newbie problem touch screen
Jason miller
United Kingdom 2005 Range Rover SE Td6 Chawton White
Hello all, I took my head unit out to check the blender motor. I didn't disconnect the battery. When I reconnected the touch screen it went blank. No logo no orange light. I have power to the screen, I have checked the amp it has power. The green message board does not light up either. I have done a hard rest still nothing. Is there anything I haven't tried or is there a procedure to reboot the screen. I have a 2005 with a fibre optic in the back. No tvs no sat nav. The Bluetooth was disconnected when I got the car.
Post #450987 15th Sep 2017 11:31am
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi mate I have been experiencing problems for last two weeks with my infotainment system I put it down to a battery disconnect also I have bypassed all relevant modules checked all fuses done hard reset no joy I have now resorted to buying a new head unit. These units are very temperamental and don't like battery disconnect or low voltage. What are you getting Land Rover screen or nothing? Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #451001 15th Sep 2017 1:17pm
jaysta10k
Have you checked all fuses the bluetooth was probably disconnected due to water leak common fault I had the same issue. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #451002 15th Sep 2017 1:22pm
Jason miller
Hello yes all fuses relays wiring. I have power to the head unit, amp, and radio control unit. The screen just does not come on not even the orange light.
Post #451007 15th Sep 2017 2:18pm
Jason miller
Am going to buy another head unit today and see what happens.
Post #451008 15th Sep 2017 2:20pm
jaysta10k
Yes best option as it can only be a defective head unit and after all they are over 10 years old plus if you look about on fleabay you can pick up 2008 model for about £200. Instead of the £2500 price tag of a brand new one😂😂 Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #451017 15th Sep 2017 4:44pm
Jason miller
Well we tried two head units and nothing. The only thing left is to put it on the laptop and see if there is anything there.
Post #451038 15th Sep 2017 8:04pm
jaysta10k
That's bizarre I fitted mine this evening and all good I had a faulty touch screen head unit after 2 weeks of testing everything it turned out to be this. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #451046 15th Sep 2017 9:35pm
Jason miller
Hello did you disconnect the battery and let it power down. Or just plug it in.
Post #451048 15th Sep 2017 9:38pm
Jason miller
Sorry I will put it a bit better. How did you fit your new one. Did you let it power down and then disconnect the battery, or just plug it in.
Post #451049 15th Sep 2017 9:40pm
jaysta10k
No I never disconnected battery I just connected all the wires and pressed the power on button mate it's really strange you got no power going to the head unit it could only be one thing a blown fuse! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #451055 15th Sep 2017 10:17pm
Jason miller
I have power to the head unit and the radio unit and amp but still nothing. There is no red light coming out of the fibre optic. I think the ecu maybe in safe mode. I just have to get on the computer now and see what's going on.
Post #451057 15th Sep 2017 10:26pm
jaysta10k
How you getting on mate never heard of ecu safe mode to be honest there should be light out of the fibre optic cable if there is power present. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #451084 16th Sep 2017 11:01am
Jason miller
The car is asleep I need to find way of waking it up. Any ideas.
Post #451096 16th Sep 2017 1:00pm
Jason miller
Well just an update on my radio problem. It's fixed, it was the radio receiver box behind the main screen that went faulty. Radio all up and work now, including the most system.
Post #451541 20th Sep 2017 9:05pm
