Home > General > Is this to cheap
Gandalf
Is this to cheap
Looking for my first FFRR mainly on auto trader found what looks on paper a bargain. It's a Range Rover 3.6 TD V8 Vogue 5dr 2007 on a 56 plate 120,000 miles 1 Former owner, FSH, Next MOT due 10/01/2018, is it worth a look the asking price sems low @ £7,690
Cheers Peter
Post #451173 17th Sep 2017 11:39am
gizze
If loads has been done and it costs you nothing over the next year or so it is a bargain, if it is problem after problem then it may bankrupt you.
There is no answer.
Is it a private seller?
I prefer to buy privately, I always have far less issues with private buys.
I think most people who have issues dump them into WBAC, auctions, trade them in to get rid of them.
So unless the dealer is decent, well known and local (or part of a main dealer network) I don't bother. Porsche 911 (996)
2015 BMW 5 Series Touring
Not got a LR of any kind at the mo, and got itchy feet.
Post #451174 17th Sep 2017 11:49am
You probably read this
http://www.fullfatrr.com/forum/post451172....03c#451172
Need to check what work has been done, MOT advisories etc.
If no work done, no bits replaced etc. then you have that all to come! Twisted Evil .
Post #451195 17th Sep 2017 6:08pm
as above there is no right answer to that. If the car has been fastidiously maintained and all the usual suspects have been dealt with then it could be a bargain. However if its just been pootled about in and nothing replaced or attended to then it could be a financial gamble.
You need to see if:
Alternator replaced
gearbox serviced
diff oils changed
any turbo trouble? done or imminent
what type of miles has it done, they don't like town driving. They are fine and can rack up good milages on original turbos if that milage is the type which lets the engine get up to temperature. do you research properly and you should be more knowledgeable when you go to look at them. There is a buyers guide in the WIKI at the top of the page, and loads of info on things which commonly go pop.... There is nothing that can't be fixed with a hammer😜😜
Post #451209 17th Sep 2017 8:04pm
rar110
It's very difficult to answer.
You need to look closely at the general condition and what has been done. Low and high mileage L322s all have a potential to cost lots.
I bought mine with 230,000km so only done a little more. It was a bargain at the time 3 years ago but I knew I would be sooner ir later be costing something. Price and a service every 10,000km is what got me in as intervals here are 12,000 and in 2009 changed to 24,000km.
I've had no regrets when repairs became necessary as I knew they were on the cards from hours of reading on here.
Every repair is an investment in its future reliability. So far the bigs things I've replaced tranny/transfer, alternator, and front air springs/shocks. I've also given it induction cleaner treatments, disabled the EGRs and cleaned the MAFs, which I hope contributes to the turbos' life.
Good luck with your decision. ______________________________
Post #451229 17th Sep 2017 10:03pm
Clive603
England 2004 Range Rover HSE Td6 Orkney Grey
How many miles do you plan to do? How does cost of the "big ticket stuff that will probably have to be fixed in my care" list compare with depreciation on a car reasonably likely not to need expensive fixes in your care?
Best answer would be if its had all the likely suspects done by a good garage but the owner has just got fed up with spending money.
Second best answer if you plan plenty of the right sort of miles is actually one in good cosmetic and body condition whose owner is bailing out before any, or any more, big ticket items. Hopefully with a worrisome noise you can use to negotiate the price down. Then take a sensible look at the "its going to have to be fixed sometime list" and just do your take on "the lot" in one hit. Expensive yes, probably £5,000 plus, but if you are aiming to put 80,000 to 100,000 on the beast and the price is right the financial maths could well work out.
On the other hand if you only plan 20,000 to 30,000 miles they could be very expensive ones!
Clive
Post #451455 19th Sep 2017 10:25pm
themule
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
On this forum, similar, well sorted examples are going for similar money. So it's not unusually cheap. Prices do seem to have dropped in the 18 months since I paid £9750 for 07 plate similar example, similar mileage. Maybe it's the diesel hate that has ramped up recently?
Post #451466 20th Sep 2017 7:40am
GGDR
I think it's just 18 months of depreciation! Cheers, Greg
Post #451468 20th Sep 2017 7:48am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
It's very true about the recent diesel bad press.
In the ford showroom last week, the salesman said, I can't get enough petrol engine cars, because of the government's bad press, everyone wants petrol, they don't understand the later engines are ok, crazy!
Post #451489 20th Sep 2017 11:09am
Gandalf
Thanks for all your thoughts Bow down seems like a FF rangie isn't the car for me only do about 7000 mls a year mostly towing a tin tent. So the search will continue would like to stick to green ovals though just hate the look of D3/4s.
Post #451515 20th Sep 2017 5:36pm
themule
That too
Post #451558 21st Sep 2017 7:26am
GGDR
...or you could spend a little more, get a sorted example perhaps from this forum. Isn't a TDV8 RR one of the best towing vehicles ever?
. Cheers, Greg
Post #451561 21st Sep 2017 8:10am
gizze
I was going to say, you could have mine for that, and that drives a treat.
Only thing I would do if I kept it would be map the EGRs out for £235.
Alternator was done, new battery was put in, parasitic drains found and removed, new tensioner, belt and waterpump all fitted in the last 12 months and drives great.
I have freshened up the interior, put on some L405 wheels with decent tyres, brakes have loads of life left in them.
Drove round for two days and 400 miles with a Snap On diagnostic machine plugged in and everything was reading perfectly.
I had all the suspension gone over as I thought that may have been causing the drain, turns it was a dodgy bluetooth module, and the suspension was said to look in great shape.
The only niggle I have on mine is slight rear diff noise at 40mph you can hear with the radio off, I didn't actually notice it, but dropped the oil and no metal in there, and had a quote of £250 for a rear diff off a 67k mile car from a breaker and quoted 2 hours to replace.
Now I am not trying to sell it as I have 3 people already wanting to come and view it when we can sort of times etc. But just saying I wouldn't write one off.
Now of course you could drive down the road and a sensor go or get a flat tyre or some Censored smash into the side of you like in any car. But I think there are ones out there that have had the niggles sorted so don't write them off. Porsche 911 (996)
Post #451582 21st Sep 2017 11:01am
GGDR
....and you are asking £7900 for yours gizze, it's a lovely car.
http://www.fullfatrr.com/forum/topic44532....f8b1e4eeab Cheers, Greg
Post #451613 21st Sep 2017 1:45pm
gizze
Cheers, I wasn't going to post as I didn't want to look like I was 'pimping it' out, but my point was they are out there on budget with loads of the big things already done. Porsche 911 (996)
Post #451619 21st Sep 2017 2:21pm
