Home > Technical (L322) > Vibration under load
davidjpowell
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
So far noticed this when towing at slower speeds up moderate hills and steeper.
Not noticed it without the caravan....
Quite a heavy vibration from the drivetrain somewhere...
At steady speeds (50 ish) I have noticed the revs don't seem very steady.
I suspect the torque converter, but am open to other ideas!
Post #451221 17th Sep 2017 9:31pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
if it does turn out to be the TC , you may want to look up Dr trannys shudder cure , available off fleebay
Post #451282 18th Sep 2017 1:37pm
