Home > Technical (L322) > Smoke after idle. |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 799 |
id say turbo seals are getting week with the smoke being white , I had a turbo petrol car that only smoked at idle , the turbo was at fault , my td6 does smoke at really , no more than a derv should so I don't know what your mates on about ?? |
18th Sep 2017 1:47pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
I sat in the car last week with the csr idling.
18th Sep 2017 7:45pm |
Videoman1959 Member Since: 11 Apr 2015 Location: United Kingdom Posts: 77 |
If I start my car after about 5 mins I smell a burning smell and white smoke escapes from under the car. The has happened intermittently, three times is three days.... not at all yesterday . Any ideas please? 'Knowledge Is Power' |
22nd Sep 2017 6:04am |
If the temperature has been 8 deg or below, it will be the fuel burner heater starting up.
22nd Sep 2017 6:11am |
I doubt it in this instance as this was a midmorning start-up. But thank you for the info. The burning smell was quite noxious really. My wife said 'are we burning petrol' ? 'Knowledge Is Power' |
22nd Sep 2017 6:21am |
If the ambient air temperature is around 8 deg or below, and the water temp is below 65 deg or there abouts, then the fbh will kick in.
22nd Sep 2017 6:42am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
White smoke is unburnt fuel. Could be a faulty injector. Have you fitted the modified cc breather or at least changed the old filter element, if not I would do that first. 2007 TDV8 VSE
22nd Sep 2017 6:47am |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1227 |
Totally agree that after a long idle it will smoke a bit when moving off, but not much and only really noticeable at night. I always try to mix driving styles to make sure the system gets a bit of a clear out every few days. Tom
22nd Sep 2017 11:26am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1689 |
Its a faulty injector/s, or blocked crank breather. Both fairly common on higher mileage cars |
22nd Sep 2017 12:37pm |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
I had exactly the same problem on a freelander, always believed it to be an injector but never actually investigated further. |
22nd Sep 2017 1:07pm |
TamHare Member Since: 22 Jun 2017 Location: Central belt Posts: 8 |
Thanks everyone for the input.
22nd Sep 2017 6:29pm |
split hoses can cause all sorts of issues on derv engines so don't be surprised if you've inadvertently fixed your smoke issue aswell pal lol |
23rd Sep 2017 8:48am |
