Home > Technical (L322) > air suspension inactive
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
So I was driving round he country lanes today which I do everyday as part and parcel of my job went over a hump back bridge not at a crazy speed and message came up "off road dont exceed 30 mph" or similar then the lights went out on the suspension controls and "air suspension inactive came up on dash".
Suspension appears to be at noormal ride hieght and car is driving normally not had any problems prior to this air bags have been replaced a while back so should be ok. Tried disconnectng battery no luck.
Any ideas how I can clear and reset it all functions were working fine all day access hieght motorway hieght etc.
Post #451335 18th Sep 2017 9:04pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
need a scan tool to remove the fault code pal , snap on solus or similar or a member close by with IId tool
Post #451338 18th Sep 2017 9:08pm
Bobcat4472
United Kingdom 2016 Range Rover Autobiography SDV8 Barolo Black
I had this problem on my L322 and after much stress found the source of the problem was a blocked pressure relief exhaust on the compressor. Removed it and had no fort her issues.
Post #451339 18th Sep 2017 9:09pm
bembo449
did your suspension still function ok then??
Post #451341 18th Sep 2017 9:11pm
Bobcat4472
Absolutely perfectly. Seems to be a well known problem see thread
http://www.fullfatrr.com/forum/topic825.ht...on+failure
Post #451346 18th Sep 2017 9:18pm
horsedentist
Can it be cleared with any of the diagnostic programes via a computer?
Post #451350 18th Sep 2017 10:02pm
Worth checking all your height sensors are still connected and working.
You will need diagnostic equipment to reset the hard fault on the EAS. You should also be able to read the faults and thus understand the problem a bit better. .
Post #451357 18th Sep 2017 11:51pm
horsedentist
Ok guys thanks for the tips found the problem rear offside sensor has become detached at the hinge point rubber grommet that holds the rod in is perished. New sensors on order the fault is in the height sensor so I can turn it off with navcoder no fault codes on eas friend checked it all with snap on.
Post #451432 19th Sep 2017 8:30pm
Same happened to me on the rear a while back. At least the rear sensors are an affordable fix with a new one, unlike the fronts! .
Post #451439 19th Sep 2017 8:57pm
horsedentist
New sensors arrived so looks like a couple of hours under the truck Sunday morning.
Post #451782 22nd Sep 2017 8:52pm
bembo449
ive recently renewed both rear sensors on mine , remember to disconnect the battery while you change them pal
Post #451796 23rd Sep 2017 8:45am
horsedentist
Well new sensors fitted but suspension still all over the place getting the snap on hooked up to it later if that don’t sort it think I will have to get it recalibrated. When it’s at standard height it thinks it’s at access mode so puts its self into off road height when I drive off?
Post #451902 24th Sep 2017 9:33am
holidaychicken
Allcomms has a calibration feature to reset the heights and faults if someone has one near by and I'm guessing IID tool as well. The fronts can go on back to front with the elbow facing the wrong way but not sure about the rear but as long as they went on the way they came off you are ok.
Post #451975 25th Sep 2017 2:23am
horsedentist
All sorted was a pig it had lost its reference point for some reason when it was at normal ride height it thought it was at access height. Consequently when I drove off it went to off road height then threw a fault again. Reset and reflashed the ecu with factory settings now all working thank goodness took several goes to clear it.
Post #451993 25th Sep 2017 8:34am
bembo449
reads like it was in transport mode to me , like mine was pal
Post #452083 25th Sep 2017 6:51pm
