Home > Technical (L322) > Transmission error |
nebc100 Member Since: 14 May 2017 Location: Altlinster Posts: 76 |
Hello All,
21st Sep 2017 11:45am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 908 |
Presumably it’s referring to the slip speed across the LUC – which usually means trouble with the GM 5L40-E. Come to think of it, most things mean trouble with the 5L40-E. I should drain off some fluid and check if it has glitter (fine metallic debris) in it.
23rd Sep 2017 6:28pm |
Thanks Phil, but the whole transmission has just been refurbished.
23rd Sep 2017 6:33pm |
Ok... To bring this thread back to life...
24th Oct 2017 7:51pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Other than the fault code, what are the symptoms, only out of interest , Phil is your man. |
24th Oct 2017 8:04pm |
No real symptoms. Drives perfectly until the error comes, then the torque converter doesn't lock. Once error cleared, torque converter works perfectly until error comes up again.
25th Oct 2017 7:18am |
