Home > Maintenance & Mods (L322) > Strange intermittent noise |
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 |
Hi all,
24th Sep 2017 3:09pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3193 |
Sticking caliper? Check the wheels for temperature after a short run. John
24th Sep 2017 3:50pm |
Well it looks like it was the exhaust heat shield which had come loose. |
26th Sep 2017 7:00pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Nice find, I was thinking torque converter, it would have been TC if it had been mine ! |
26th Sep 2017 7:06pm |
I think there may still be an issue with the TC which is causing the judder under gentle acceleration. |
26th Sep 2017 7:31pm |
Have you checked for the caliper? Symptoms like running over a cattle grid, which is similar to what you described, can be caused by a sticking caliper.
26th Sep 2017 7:49pm |
Yes, it’s be3n up on the ramp and had everything checked. |
26th Sep 2017 8:37pm |
Dieterf Member Since: 24 Apr 2016 Location: Cape Town Posts: 40 |
My TC was a rumble under light constant throttle load up a slight incline
27th Sep 2017 7:05am |
Mine was like the cattle grid or the rumble strips at the side of a motorway, not a thump thump. Thump thump could be a worn UJ maybe or suspension arm ?
27th Sep 2017 6:20pm |
The main noise has been cured now. It’s more of a feeling than a nois when juddering on acceleration and is very mild. |
27th Sep 2017 6:54pm |
Injector maybe, have you got any codes ? |
27th Sep 2017 11:43pm |
Thats a great document-Thank You
28th Sep 2017 6:33am |
Following the noise of the heat shield I developed another similar noise. When I checked this was obviously relayed to the rear wheel as it was extremely hot. Turns out the brake calliper was sticking.
18th Oct 2017 7:04pm |
