Home > Maintenance & Mods (L322) > No heat from heater?? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2213 |
Hi all everything is working fine apart from no heat coming from the heater on auto or max - air lock? if so how to get rid? |
8th Oct 2017 4:17pm |
bertie1 Member Since: 30 Sep 2017 Location: kent Posts: 100 |
have you turned the knob in middle to red if not it blows cold in both front and back |
11th Oct 2017 1:34pm |
Right well in true Rangie style it couldn't be just one thing so the thermostat wasn't opening properly and the blend motor is stuck or at least has limited movement so replacing all no point in my mind freeing things up at 10 years old I just change the parts |
20th Oct 2017 9:45am |
