Home > Maintenance & Mods (L322) > Range rover l332 aircon |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
If it is still cold, don't worry - mine does it from time to time. basic description below. If it does it for a few days and then stops being cold then you have problem.
15th Oct 2017 9:41pm |
banser Member Since: 04 Mar 2016 Location: wicklow Posts: 3 |
I searched for an answer to this on landrovers forum and apparently it's very common its condensation in aircon the drain tubes become blocked just don't know where the drain tubes are on range rover |
16th Oct 2017 6:08am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3186 |
Two tubes, one hanging down either side of the gearbox. John
16th Oct 2017 7:59am |
Thanks will have a look when weather improves |
16th Oct 2017 8:08am |
When i have been parked for a while with the engine running and the aircon on I get quite a puddle underneath from the drain tubes |
16th Oct 2017 8:29am |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
Good luck with that........ I've had the same with mine from time to time, try it with the recirculation in different positions and see if it makes any difference. |
17th Oct 2017 8:25pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1225 |
I always thought that was a Range Rover just marking it's territory!! |
19th Oct 2017 8:17am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34871 |
19th Oct 2017 8:20am |
