Home > Maintenance & Mods (L322) > Drivers Side Arm Rest refurbish |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 |
So I had to remove the drivers door panel to get to the lock actuator for replacement/assessment. Figured I'd redo the crappy armrest vinyl and foam. Also wanted to repaint the door handle trim. Should be straight forward, right? Learning to do it the first time rates about a 7 on the frustration level. I hope, for those that more time than money or sense, this helps.
16th Oct 2017 3:04am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Thanks. Something I will have to do one day. ______________________________
16th Oct 2017 9:31pm |
I wish I had a couple of bad armrests to play with using the heat gun to shape the vinyl better. I didn't glue the vinyl to the foam at all. I don't know if that would help or hinder the shaping. There is a local upholster here that does classic and antique cars. Maybe I can pick his brain. |
16th Oct 2017 10:17pm |
Here is the color difference.
18th Oct 2017 3:01pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
What is that Rust-oleum product and what is the colour? Is that what you used on the door hand surrounds? Ron B. VK2OTC
13th Nov 2017 9:22am |
Yes I painted the handle trim with this slightly darker color. The previous picture is the trim before painting next to the can color.
13th Nov 2017 2:07pm |
Excellent. I'll have a look for it.
13th Nov 2017 10:16pm |
