Home > Technical (L322) > RR TDV8: Error P0407 EGR Sensor B Circuit Low |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1234 |
On a freelander 2 TD4 ... the EGR Sensor B circuit error actually refers to the throttle body position sensor of the air intake system. It is possible this is the same on the TDV8.
17th Oct 2017 5:41pm |
If you are still stuck, you need to find the full error code.
17th Oct 2017 5:51pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
Have exactly the same code on mine and i can clear it but comes straight back again. Asked on here before about it but didnt get any responses so asume its not a common one. I have no issues or errors and can see the egrs opening and closing on my iid tool so just put it down to a small gremlin as theres always a code showing for something. Found some info on the disco 3 forum and that was down to a cable unplugged in the inlet manifold.
17th Oct 2017 6:47pm |
steph_boldt Member Since: 16 Feb 2017 Location: Mainz Posts: 10 |
Unnecessary quote removed
17th Oct 2017 7:36pm |
I think my case is a bit different. When I connect my tool and look at the online data, I can see that the positions of the EGR valve as well as of the throttle body positions do not change at all. They stay constant in one value. So it may be the throttle body position sensor! Symptoms: I really don't feel any! After doing all this, the engine is running very smooth and it seems to have gained in power and in throttle response. - I would not really care, if there wasn't the emissions test every two years. They will certainly not accept EGR-valves not working... |
17th Oct 2017 7:44pm |
tomcon1 Member Since: 25 Apr 2018 Location: North Warks Posts: 2 |
hi did you ever resolve the issue - I have just replaced the egr valves and have the same error code showing?
25th Apr 2018 12:02pm |
Hello Tom,
25th Apr 2018 8:26pm |
thanks for the response Stephan - much appreciated. The new ones that I fitted were valeo EGR valves (who supposedly make the oem ones) but not from JLR. I will refit the old ones this weekend and hopefully the faults will go away.
26th Apr 2018 8:40am |
Tom, good luck! I am very interested in hearing about the result!
26th Apr 2018 12:18pm |
I would also have a look at the throttle position sensors as the workshop manual advises to check these with that code. Easier to check first before stripping out to put he old egrs in! Current 2007 TDV8 Vogue Buckingham Blue |
26th Apr 2018 6:02pm |
