Rear Heater Blower - Fixed | |
After about 6 years of owning the car and the rear heater blower never working properly, I thought I'd find out what the problem was.
The issue was whenever the rear fan was put on, there never seemed to be anything coming out of the vents. Today I found out why, and it was quite easy to fix in the end.
There is a flap at the back of the vent that should open when the fan is turned on. When the fan is turned off, it should close again. However, there is a piece of plastic that links between the fan control and this flap that can easily come off. Mine was sitting near the bottom of the fan, though I daresay it could get lost easily.
Some pictures of the problem, and the fix:
| Click image to enlarge |
The assembly all apart.
This is the l/h side of the vent showing where the link should be.
This is the plastic link that connects the two.
And with the link re-connected Current:
- 2013 L405 4.4 TDV8 Vogue
Sold:
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
