Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1127 |
Hi, I replaced the seat heater last week not had it working since I bought the car was surprised it took so long to heat up but when it does it`s hot |
26th Feb 2018 3:15pm |
Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 50 |
It might take a while but its well worth it in the end FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 |
26th Feb 2018 3:36pm |
Its just a matter of accepting the fact that with these cars you need to put your hand in your pocket if you want to maintain all of the benefits, after you have crossed this bridge the smile will eventually return to your face and the cost is soon forgotten, good luck mate FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 |
14th Mar 2018 9:54pm |
philip600 Member Since: 04 Feb 2018 Location: North East Posts: 36 |
Hi,
14th Mar 2018 10:03pm |
Good luck Phil, at around £240 each for the seat back fan units plus fitting i hope for your sake the dealer comes up trumps FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 |
14th Mar 2018 10:34pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
I'm trying to get mine repaired. I've bought a new one but on principle I'm determined to find somebody who can repair these units.
14th Mar 2018 10:53pm |
An update on mine: fixed with a new unit in the seatback. It's warming up now as I'm writing this for the first time in a few weeks. Oooh feels so good. Missed it!
17th Mar 2018 4:43pm |
An update on mine: just fitted a new unit in the seatback. I'm writing this from the car, it's warming up now for the first time in a few weeks. Oooh feels so good. Missed it!
17th Mar 2018 4:48pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
As posted elsewhere by others, I would expect it is the thermistor that fails.
17th Mar 2018 11:26pm |
Thx John!!!!
18th Mar 2018 1:38pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Greg, can you switch fans - bottom and back to see if it is your fan at fault?
18th Mar 2018 4:27pm |
Thanks Nino, I think the seat unit and the base unit are not interchangeable. BUT driving about today, I thought if only I could test the back and the base separately - then I remembered the push switch on the dial. I turned the base off and the back worked fine. Ran for a good hour and I was getting hot!
18th Mar 2018 7:14pm |
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 |
Greg
18th Mar 2018 9:11pm |
Hi Mark.
18th Mar 2018 11:09pm |
