Home > Maintenance & Mods (L322) > Possible Turbo issue sounding like a siren! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34913 |
i'd check out the hoses first...if possible take them off and look on the underside and inside.. ... - .- -.
24th Oct 2017 11:11am |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 292 |
This is first port of call cheers Stan. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
24th Oct 2017 11:17am |
This is s bizzare one guys still got the high pitched siren like sound when car is ticking over its low pitched then when I give it some throttle it get louder and more high pitched but fades off at about 2000rpm any ideas please. Checked all hoses and air filter box etc all good
1st Feb 2018 10:43am |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
I think your turbo is on the way out.
1st Feb 2018 6:31pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
My bmw 530d began sounding like a police siren. Indeed it was the turbo failing but I just left it and traded the car in! |
1st Feb 2018 6:53pm |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 |
Is it a Td6? |
2nd Feb 2018 12:55am |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
Sounds like turbo is failing Alex
2nd Feb 2018 10:18am |
Yes its a TD6 but I have had no reduction on performance whatsoever car is running fine etc... Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
3rd Feb 2018 12:02pm |
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 |
if you require a new turbo ,google best turbos Birmingham.
4th Feb 2018 11:39am |
Hi guys this is a strange one I can hear the whining noise more so under revs only unto 2000rpm at the back of car near rear tyre could this be diff related any ideas the sound is more noticeable at rear of car than in engine bay after more investigation.
4th Feb 2018 7:26pm |
more noticeable at rear of car than in engine bay by sounds of it Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
4th Feb 2018 7:27pm |
Our Td6 was exactly the same. Noisy up to about 2000rpm, then fine. I was convinced at one stage that the whining was loudest around the n/s rear wheel and thought it might be the cill mounted fuel pump. I took it to my local garage for them to listen, we put it over their pit, ran it up to 1500rpm and put a long screwdriver blade on the turbo, and with the handle to your ear you could clearly hear it whistling.
4th Feb 2018 11:47pm |
Cheers for info really strange as doesn't explain why we can hear the whining siren noise at rear wheel area more so than in engine area! but when sat in car you can hear it in drivers seat
5th Feb 2018 11:39am |
Yes, it’s very odd how the sound seems to be coming from the rear wheel area. Try the screwdriver trick. |
5th Feb 2018 11:41pm |
