![]() | Home > Maintenance & Mods (L322) > Timing chain tensioner |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587 ![]() ![]() |
Jeez, those springs are different. The old one has far fewer coils.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2297 ![]() ![]() ![]() |
I ordered it from dan at duckworths was about £70 from memory Current stable:
I shall have to find a local supplier. Ron B. VK2OTC
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I did mine but it was already the new type and I found it a right mare to get a socket on until I used a deep socket and swivel head bar.
Which crush washer for the tensioner? It didn’t come with one and I don’t recall removing so guessing it was stuck in place I will stick my finger around it tomorrow for a leak check Current stable:
This one, this shows the part numbers, they are available all over ranging from about 50p for a genuine one from landrover which is the RYX number
Still no rattle and touch wood no leak there even though there was no new washer good work I thonk Current stable:
Mine still has a rattle for a while until the engine warms up a bit so although my tensioner is the new type I may still pop it out and have a look.
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
I did mine 2 months ago and my guide failed days later. Maybe just bad luck and bad timing . The old tensioner was very stiff with not a lot of spring in it compared to the newer part.. anyway dropped into the deep end and spent 3 days stripping and replacing chains/guides..what I did notice when I removed old guides was it was relatively easy to break them so they were obviously ready to fail |
It’s not a bad job is it as long as you do a bit of prep and get the right tools.
