Home > Maintenance & Mods (L322) > Troubleshooting canbus error? |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
Right been up on this glorious rain now I have all ‘aftermarket’ canbus devices disconnected and off the canbus lines ... still get the same air suspension inactive faults... any ideas? Current stable:
4th Nov 2017 10:04am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1239 |
Are you clearing all errors ?
4th Nov 2017 2:28pm |
Cleared all the faults - now just have a fault stored in abs for steering angle sensor is this the possible cause? Cheers Current stable:
4th Nov 2017 6:11pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
I had all sorts of those fault codes, eventually I replaced the steering angle sensor and it fixed them all. |
6th Nov 2017 2:59am |
Did you manage to take the shortcut of removing the four bolts without removing the dash? And did the lights go out without recoding or did it need coding first? Current stable:
6th Nov 2017 8:11am |
Also aside from no traction or abs is it causing any harm driving it as is? It blows up and drops on startup ok and isn’t on the bump stops from what I can tell Current stable:
6th Nov 2017 1:53pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 818 |
I had this and it was my ABS module that had gone squiffy. Replaced it and all has been well.
7th Nov 2017 12:24pm |
Ok - shall I check the abs plug? Also can I drive like this? Current stable:
7th Nov 2017 2:50pm |
Have a look for corrosion in the plug and any dampness, and as you've probably noticed the suspension works ok on the road. The only thing was I couldn't adjust the suspension, but mine was intermittent only failing when the engine temps got up to normal and the heat was expanding a soldered joint causing the fault. It's very common apparently ______________________________
7th Nov 2017 2:58pm |
Dan, I got the 4 bolts out without tsking the dasjha aprt via short cut, but a sod of a job for access, ended up taking the dash apart to refit as I was wrooried about cross threading the upper bolts, acces is a sod, once dash out it was a quick refit.
9th Nov 2017 3:47pm |
Can it be coded without iid tool I have pa soft and I have inpa? Anyone done it completely without dash removal? Current stable:
9th Nov 2017 4:53pm |
Also is it hard to get in the right place or is there a master spline?
12th Nov 2017 9:59am |
https://www.landyzone.co.uk/land-rover/ste...es.312092/
23rd Dec 2017 3:49pm |
