Home > Technical (L322) > Starting issue.
Mart67
2005 Range Rover Supercharged 4.2 SC V8 Java Black
Starting issue.
A few months back I replaced the contact side of the ignition switch in my 06 SC after constant issues with it intermittently failing to start.all has been well since I changed the switch until a few days ago when I'm getting the same kind of issue. First flick of the key gives me a tick as if the battery is flat, if I try it a few times it will start but today I held the key over in the start position and it eventually sprung into life??? Just like the contact side of the switch is bad again?? I fitted a brand new genuine unit so can't see that being at fault???? Can't be battery because it will start the more times you try it???
Any ideas??????????
Post #456946 11th Nov 2017 8:04pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Dodgy starter motor, bad earth to motor, bad + connection to motor. If there is a click it sounds ;like the starter solenoid is working.
Post #456985 11th Nov 2017 11:44pm
