Home > Technical (L322) > Testing speed sensors. |
Some youtubes links
20th Nov 2017 10:10am |
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 |
Thanks for the information Joe, i have watched several of those videos to make sure i was on the right track, i first tried to check the sensors through the main plug on the ABS ECU and then i tried each sensor to eliminate the possibility of a damaged or broken wire, so i will get a known good sensor and see what is what.cheers. |
20th Nov 2017 12:07pm |
Well i am back again the problem persists, when checking the sensors i get conflicting results, having watched several tutorials on how to test the sensors i removed them and set about testing, the results were all fail so i went out and bought another tester. No difference,
30th Nov 2017 4:25am |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
Hi did you ever resolve the problem , you had measuring the resistances .
24th Sep 2018 12:46pm |
