Home > Technical (L322) > 2003 FF HSE TD6 ,which BMW diesel engine |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Seeing as you'll have the engine apart this is a very good upgrade https://www.ebay.co.uk/itm/BMW-E46-318d-32...SwuMFUmTCE
26th Nov 2017 7:45pm |
wack61 Member Since: 17 Nov 2017 Location: Cheshire Posts: 104 |
This new engine has done 30k less than the old one, it has the fuel pump and injectors in it but not the turbo , Steve is planning on changing the inlet manifold as suggested but also pump and injectors from the old engine
28th Nov 2017 9:12am |
I wouldn't bother personally, but I would have the pump, injectors, starter, alternator off the old lump as spares! Why change unnecessary parts, I'd stick with the parts it came with and save as much of the old engine as possible.. You know that everything is good on the engine your car came with except 1 cylinder Yesterday I couldn't spell Engineer... Today I are one!
28th Nov 2017 10:20am |
Thanks, had a chat and we're going with the new engine as is, I'll end up with loads of spare parts, AC pump, wiring looms, alternator , sensors , not sure I'll go as far as pistons and internals but all the bits on the outside will be going in a box, not that I'm likely to need them as it's going to be mega reliable |
28th Nov 2017 7:45pm |
