Home > Maintenance & Mods (L322) > Heater matrix feeds |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2213 |
Gents there are three pipes which go through the bulk head to the heater matrix two come from the valves mounted on the nearside wing which I assume are flows for the left and right ?? the other has a valve on the bulkhead then a loop and a return to the cooling system for the supercharger - what does this pipe do ? is it the return from the matrix? also what is the valve?
30th Nov 2017 6:51pm |
Sorted there are two inlet (left and right) one outlet and the valve is an isolator for the FBH |
30th Nov 2017 8:52pm |
