Home > Maintenance & Mods (L322) > EGR? |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
I would take it out, checked for fatigue/intact, cleaned, ensure it closes and disable it. ______________________________
4th Dec 2017 7:47am |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
Strangely, the problem has disappeared after a few uses of the beast.
4th Dec 2017 5:20pm |
If they’re working ok maybe go straight to disabling the EGRs. You could use some induction cleaner before hand. If you have an IID Tool it will indicate percentage open from memory. ______________________________
4th Dec 2017 9:55pm |
DavidS Member Since: 23 Jul 2014 Location: Valencia region Posts: 73 |
If you where to map out the egr's would you need to fit blanks? |
5th Dec 2017 1:52pm |
Just an update...
5th Dec 2017 8:27pm |
Further update.
12th Dec 2017 2:10pm |
mrtidy Member Since: 31 Aug 2015 Location: Stockport Posts: 211 |
Surely a tank full of super diesel woudnt cure it?..my iid tool says both egrs at 0% commanded. and position one is stuck at 5% and one stuck on 7% and the orange check engine light is on.car drives fine though but it's going in in Friday for new egr valves. 2009 Vogue SE Zermatt silver |
12th Dec 2017 3:25pm |
Well Shell Ultra makes claims for 'cleaning' the engine - that's why they charge 8p/l more for it.
12th Dec 2017 4:40pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
When you use the IID tool does it show the actual position of the valves as 0% as when I use mine it registers the actual as 5% as a minimum but when I record them and pull the graphs they then show as low as 0% from this so not sure if they are only closing to max 5% or if this is the lowest figure the live value on the IID tool shows? Current 2007 TDV8 Vogue Buckingham Blue |
12th Dec 2017 6:59pm |
My iid tool says the position is 5% and 7%.Commanded says both are 0%.nothing changes no matter what speed I'm going and I have 2 egr fault codes and the orange check engine light is on 2009 Vogue SE Zermatt silver |
12th Dec 2017 7:43pm |
Mine both show 5% and commanded at 5%
12th Dec 2017 8:30pm |
