Home > Maintenance & Mods (L322) > Power flush for 8HP70 gearbox? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
Counter of beans,
5th Dec 2017 10:08pm |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 |
OK, so AJAC8 says it's wasting my money at this mileage. But Mikey disagrees and says I should have already done it at 50k, and Very Disco agrees with him, pretty much. Cam Tech Craig says to service the gearbox every 30k but isn't clear whether that means dropping the sump, or flushing, or both. Meanwhile JLR say not to bother until 144k!! I'm interested in all the replies, genuinely. But can you see how I'm confused? |
5th Dec 2017 11:29pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16165 |
C.O.B. :-
5th Dec 2017 11:39pm |
Craig, are you able to calculate what % of fluid you change by just dropping the pan from the amount of new fluid you use to fill it up? 50%+?.
6th Dec 2017 9:18am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Mike, you're right the OE fluid, sump etc will be about £240
8th Dec 2017 11:24pm |
Gonna,
9th Dec 2017 10:16am |
Not sure if this guy is doing it right or wrong but gives you an idea of what's involved:
9th Dec 2017 11:14am |
luciogodoy Member Since: 08 Nov 2017 Location: Winchester Posts: 10 |
Hi all
10th Dec 2017 1:15am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
This is ZF PDF:
10th Dec 2017 10:22am |
Just wondering how people's shift quality is?
17th Dec 2017 3:16pm |
When I had my trany service, after the flush, ZF technician took car for a drive, I went with him, and drove car for 15~20 min. with laptop in his lap. he said after the flush treni needed software flush to. I did not have any problems with trani before nor after and in all honesty could not tell any difference after fluid change.
17th Dec 2017 5:16pm |
Mine was reset to factory settings??
17th Dec 2017 7:07pm |
