Home > Maintenance & Mods (L322) > Air suspension inactive and HDC warning after Strut replace |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 |
Using the iidtool I deflated the system, changed the struts and then re-inflated with the re-enable EAS function. I'm not sure I completed it correctly. There was no notification that the re-enable was completed. Now I'm getting the listed error messages on the display. System seems to be holding air and height. Front R and L are off by about 1/2 inch. Any suggestions? |
5th Dec 2017 4:36am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2300 |
With HDC inactive I suspect an ABS sensor fault as that will also trigger a suspension fault. |
5th Dec 2017 5:03am |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 816 |
Have you done the steering fully left then fully right? It could be something as simple as that... ______________________________
5th Dec 2017 9:52am |
I'll try it today but why would it be necessary? Battery was not disconnected. Track rods weren't disconnected. ABS sensors weren't disconnected. |
5th Dec 2017 2:02pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1233 |
maybe it just knows that the system has been worked on.... they are fickle things.
5th Dec 2017 3:27pm |
No disconnect of ABS but you need to remove the lines from the strut holder. Yesterday when the wife had the RR is when the warnings came on. I had only put about 15 miles on it before this and hadn't gone over 35 MPH. I cleared the codes when she got back. This morning had to go about 30 miles on highway. I did the left right steering wheel turn before heading out. No warnings yet. It wouldn't drop to highway height until I held 70 MPH for about 1 min. So I'm guessing I haven't actually damaged sensor in the refit. |
5th Dec 2017 4:20pm |
