Home > Maintenance & Mods (L322) > maybe a stupid question - but jacking with deployable steps.
GavinBell
Romania 2012 Range Rover Westminster 4.4 V8 Santorini Black
Hi,
Been searching but not really found a clear answer.....
my 2012 Westie has deployable steps... and in the next couple of days going in to have winter tyres fitted and it will probably be the first L322 they have ever worked on....
Do I need to get the steps off? and if so how to do it? the LR fitting guide in the wiki is not clear and it is -7 and snowing outside!
Should I get them to use the jacking points in the manual with a trolley jack to avoid them sticking on a pillar lift and extending the airbags ( they did that on the D2 and induced a leak!).
Any other good advice for wheel removal / fitting at a commercial place?
Going for Continental WinterContact TS850P - get good reviews from big SUV driving friends here - and had a 2 week wait for Alpin 2 s.
Amazed at the smile the Westie puts on my face - found myself quite happily going round town in circles today ... normally frustration would set in!
Thanks in advance
Gavin Series 2a LWB Hardtop - ex British Aerospace that was then used in an armed robbery! not by me!
2 door V8 1979 Range Rover
A slight Subaru blip..
110 County 200tdi
R reg 300 tdi Discovery Aviemore - gone to a local enthusiast to be resurrected in Transylvania
2003 TD5 Discovery2 - now sold
and the 2 wheeled Range Rover - BMW R 1150GSA
and finally the big lady of my dreams... 2012 Westminster - gives me a smile every morning
Post #459731 5th Dec 2017 9:04pm
Deployable steps need to be either off or deployed to use the jacking points. If they will undo, the steps can be removed with an allen key (which is probably in your boot). However, I cant get the bolts out of mine and in trying, the heads have started to round so I don't bother with that route now. But I did fit my winter tyres today without issue (Wintrac extremes). There's a sequence to lock the steps out (its in the manual) but I can never remember it so I just leave a door open so the steps stay deployed. Easy lift from there with the Sprinter bottle jack (search on here for where to get one) and wheels quick to change.
I think your concern for the airbags with wheels dangling is misguided. To remove the wheel for any action it has to be off the ground so by definition dangling. If that's enough to cause a leak then its going to happen sooner or later cos there's obviously all sorts of reasons you might need a wheel off.
There's been a couple of group buys on here for a wheel bolt alignment guide. I should have bought one but never got in in time! The wheels are heavy and the hardest bit is lining them up to mount them. If I'd bought one of those guides it really would have been an easy job! Mike - MPx
Post #459737 5th Dec 2017 9:32pm
Easiest thing in the world is to open the door then unplug the step! Plug is at the front of the step (by the front hinge) Thumbs Up
Post #459777 5th Dec 2017 11:55pm
j_rov
How about trolley jack off the chassis rail behind the steps? Is that possible/doable/safe/non-damaging? __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #459832 6th Dec 2017 5:55pm
j_rov
OK, tried this myself, not possible unless you have a particular type of trolley jack with a tall pad. The jack's arm fouls on the steps.
Bottle jack possible, but easier to just deploy the steps and leave them out. __
Land Rover History:
1976 Series 3 2.25
Post #459912 7th Dec 2017 8:59am
GavinBell
All sorted - steps out, bottle jack on front point and an air jack under suspension ... for front
Somewhere on chassis for rear...
A few suspenseful moments until the suspension sorted itself out... Series 2a LWB Hardtop - ex British Aerospace that was then used in an armed robbery! not by me!
110 County 200tdi
Post #459916 7th Dec 2017 9:44am
