Home > Maintenance & Mods (L405) > Rear luggage fuse box
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
Hi - can anyone offer any help or tips to access the rear fuse box located in the luggage area. Suspect FBH fuse blown so need to replace. Manual says 'grasp panel and give sharp pull' to remove. Believe me I have been pulling on it like my life depended on it and it won't shift !!
Thanks 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #461034 16th Dec 2017 1:53pm
Weegie
Have you tried with the flap below it raised? The one that covers the cubby hole in the boot floor. It can sometimes jam the side panel. John
GAP iiD BT
Post #461036 16th Dec 2017 2:06pm
Its kind of hinged at the bottom due to the way it fits - so you need to be pulling the top -
Post #461039 16th Dec 2017 2:39pm
CMJ
Thanks all. Once I saw the picture above I was more confident in my approach and viola. Panel removed with no breakages. Also needed to look at the fuse box in the front passenger side. And that’s not as straight forward either as the old l322. So much for progress. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #461152 17th Dec 2017 4:09pm
