Home > General > 2007 vogue at a good price?
bladeage
I am off to look at a tdv8 on Wednesday, its only a vogue but the spec seems much higher, can someone take a look and give me some advice ? ebay eBay Item No. 292361549421
Post #461967 23rd Dec 2017 8:37pm
Looks a nice car, but nothing OTT on the spec.
The tow bar is a third party one and not LR
If the sound system is really premium, it will say Logic 7 on the grilles, otherwise its the standard (still pretty good) system
Post #461970 23rd Dec 2017 9:16pm
bladeage
thanks for the info on the harman kardon stereo, although I thought all facelifts had the logic 7 fitted as standard? also already wrangled the car down by a grand.....hope it's as good as it looks in the pictures !
many thanks for your time !
Post #461973 23rd Dec 2017 9:25pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Don't know what DAB it has as but it looks like a std vogue to me? _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #461979 23rd Dec 2017 9:57pm
Paul thornton
Looks nice but as others have said nothing OTT on the spec. Price is about right.
It's actually not too far from me.
Tow bar does ruin the looks a bit but that's something you could sort at a later date.
Post #461983 23rd Dec 2017 10:28pm
bladeage
hi, yes I heard the turbos can be problomatic, is this really a common issue? I have also got the price down to 8k for it which looking around seems a good price?
Cheers all.
Post #462015 24th Dec 2017 4:02am
The turbos have been known to go - seems to be a bigger problem on the sport for some reason.
2007 seemed a bad year for alternators - they seem quite fragile. - the Rear calipers can become sticky but refurb units are relatively inexpensive - mine also needed a new air suspension compressor, but again, not huge money
Post #462021 24th Dec 2017 9:12am
bladeage
ummm yes, the towbar, surely you would fit a removable one for the few extra quid?
one other thing I was wondering is what the gearboxes are like in the tdv8?, having a 2005 x5 currently with the zf box I know is pretty chocolate, mine shunted slightly when I bought it 40k miles ago but has not got any worse although the rear bangs from time to time (subframe bushes going I think).
Have a great Christmas eve !
Post #462040 24th Dec 2017 12:31pm
A few extra quid Laughing You'll need to sit down to hear the price of the official unit.....
Gearboxes seem solid - not heard of any particular issues with them - the older TD6 had that problem.
Post #462059 24th Dec 2017 4:28pm
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Nothing wrong with a Vogue , good spec , would love to upgrade , but still enjoying mine .
Post #462063 24th Dec 2017 4:48pm
OEM DAB on a 2007 car? Not likely.
“Fully loaded” is a oft used phrase but in reality is means little, even lees on this example has it doesn’t have climate seats, RSE etc etc etc. Got - 2017 SDV8 Autobiography in Loire Blue
Post #462085 24th Dec 2017 6:13pm
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
Certainly looks like a standard Vogue - nothing wrong with that unless your a real softy and want climate controlled seats. Personally I wear underpants Laughing . From the pictures both seats look well worn and in need of refurbishing so may be worth pricing the cost of that in as jobs to do. Also check the heated steering wheel works as well as all seat heaters as common failures with a well used motor.
Post #462093 24th Dec 2017 7:19pm
bladeage
thanks for the replies !
coming from a 2005 x5 the toys are/seem much better, even at the vogue level and unfortunately my budget won't stretch further than 8k...ish. The mpg does not phase me at all because on my 18 mile round trip every day , the X5 is only doing 26 mpg anyhow and does 25 mpg with the twin wheel caravan behind. I actually thought the seats looked pretty mint condition, maybe I am missing something??
Yes....just looked at the proper towbar......eye popping price !!!!
Have a brill crimbo everyone and thank you for all the comments !
Post #462111 24th Dec 2017 9:37pm
Clabs
Bladeage
It does look reasonable but not screaming out at me - pretty much standard Vogue spec (which is actually pretty good) and aftermarket DAB.
The comment about the seats probably comes from the last pic in the advert - the drivers seat base looks well worn and also looks like it has been poorly touched up in an effort to hide the inevitable scratches that really show on darker seats. It also looks like it has almost worn right through in one spot.
Call me a cynic but to my mind, not sorting out one of the first things you see when you get in the car would kind of have me worried about the multitude of things you cannot see.
Good luck in your search mate and Merry Crimbo to you too )
Cheers, Mark
Post #462118 24th Dec 2017 10:29pm
TDSIX
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
The seat just looks normal not me. Car has over 100k, the driver seat has some sagging which is only to be expected. The other marks just looks like water (you can see it is raining), there is no touch up or holes, I think it's water and a reflection of the interior light you see.
Looks like a decent car to me and if you have negotiated a £grand off the price then it's now a pretty good deal.
Post #462143 25th Dec 2017 11:38am
