Home > Maintenance & Mods (L322) > Rear doors locking fault and steering. FIXED!!! |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3057 |
Deffo the bcu. U could try a second hand one on eBay for £100ish. Make sure it’s the part number impending 22.
24th Dec 2017 4:57pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Yep, +1 for BCM. Second hand is more trouble than it's worth. I think the module stores data like mileage etc. So it's a pain to change it to another car. Then of course you could be doing it again in 6 months. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
24th Dec 2017 5:27pm |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 |
I'd pull a rear door lock and test power it. I did with a 9v battery. PO bought the beast with about 100k miles and bother rears and drivers door locks were dead. If you can get 10 or more cycles without a fault then I would assume the locks are good. Also if you love the truck think about investing in an iidtool. Worth every penny. |
24th Dec 2017 5:35pm |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 452 |
I agree with Grofus and Dolphinboy - it sounds like a typical BCM problem
24th Dec 2017 5:38pm |
Ken_Curtis Member Since: 24 Dec 2017 Location: Up North Lad Posts: 13 |
Thanks for the reply.
24th Dec 2017 5:47pm |
Hi All
24th Dec 2017 5:59pm |
If £300 includes the module, then it's very reasonable. Hopefully you won't need it for a while yet.
24th Dec 2017 6:44pm |
I bought my new BCM from Ducky Dan - site sponsor "duckworthparts". He was the cheapest I found.
24th Dec 2017 7:07pm |
Many thanks for the replies.
24th Dec 2017 7:51pm |
Use a good Indie and it's about an hour's labour. £40- £60 should cover it. If you have a gap iid BT I think you can do it yourself. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
25th Dec 2017 7:53pm |
Well, I thought the reset had fixed it but the gremlins have returned with a vengeance today.
26th Dec 2017 1:36pm |
Hi All
27th Dec 2017 9:51am |
I got called back and the car is booked in this Friday morning to get it plugged in to a diagnostic machine to verify 100% its the BCM causing the issue and rule out wiring.
27th Dec 2017 12:53pm |
Sounds like a proper plan. I'd assume these suffer bad solder joints from vibration over time. Unless it got drowned at some point. |
27th Dec 2017 3:25pm |
