Home > Maintenance & Mods (L322) > SRS Airbag Light |
Crispian22 Member Since: 25 May 2017 Location: Midlands Posts: 133 |
First thing I'd do is give the battery a good charge,wether newish or not it could be run down. |
30th Dec 2017 6:16pm |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Thanks for that. Battery is fine and spins and starts engine quickly , as well as have 2 x good trips. Dont believe the battery is the issue though. I will hook up the charger and see what I get though to be on the safe side. I believe I am correct in stating that as a fault is currently registered it will be stored so will require software to reset and clear it. |
30th Dec 2017 6:34pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34912 |
my old td6 had a airbag light come and it was the occupancy sensor in the seat base that was faulty. ... - .- -.
30th Dec 2017 7:00pm |
Cheers Stan - Thats my line of thinking seeing it was all OK until the missus sat in the passenger seat. |
30th Dec 2017 9:46pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
Same with mine. The light occasionally comes on, but only when I have a passenger and they are moving about. It is the sensor under the seat. No longer FF owner but still interested. Present car Jaguar XE
1st Jan 2018 1:44pm |
Carl 40BMI RRSC Member Since: 02 Jan 2019 Location: Coventry Posts: 8 |
Hiya, did you manage to get it sorted cos I am having the same issue. I’ve heard you can bypass it but I can’t even find the module? I have a 2005/6 Vogue Sc. Any help would be appreciated. |
27th Feb 2019 9:44pm |
